How do I keep the bearing together?
I down loaded model of a bearing from McMaster Carr, when I try to mate it in my assembly it comes over piece by piece. How do I keep the bearing together?
jakeramsley Member, Moderator, Onshape Employees, Developers, csevp Posts: 665
If everything is in position, use a group command on the parts of the bearing. This will cause the parts to move relative to one another based on their position when grouped.Jake RamsleyDirector of Quality Engineering & Release Manager onshape.com6
