Hole Tool, tapped holes
lni64lni64 OS Professional Posts: 38 ✭✭
The tapping feature does only work when "blind in last" is selected, "through" doesn't work
Bug or feature?
    viruviru Member, Developers Posts: 619 ✭✭✭✭
    @lutz_niggl , It is working fine when through also selected. Kindly refer below image.
    edited January 2016
    It doesn't work for me:
    With blind in last everything is fine:
    Changing to "Through" there is no tapped diameter:
    Edit: Just saw that it sets the clearance setting back to "Clearance". Reactivating Clearance & tapped" inserts the tapped diameter in both parts which also is not exactly what you usually want:
    I'm quite sure that this is a bug.
    edited January 2016
    @lutz_niggl , Yes you are right. This is bug happening same with me.  Kindly report this issue with Onshape support team.
    andy_morrisandy_morris Moderator, Onshape Employees Posts: 87
    edited January 2016
    Hi @lutz_niggl , this is a bug where we are not displaying the correct icon in the dialog when you change the end-condition. The value of the tap drill size is correct. I have opened a new support ticket for this issue.
    Andy Morris / Head of Product Design / Onshape, Inc.
    NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,437
    In the meantime you will have to set your hole depth deeper than the thickness of the two plates to get clearance and tapped and through.
    sam_wehrlisam_wehrli Member Posts: 12 PRO
    I'm searching around the forums for a solution to my problem, and I came across this thread. How did you get the "blind in last" function to work? I am stuck. No matter how I change the depth or any other variable this function will not work. any help would be greatly appreciated. I made my project public.
    https://cad.onshape.com/documents/844a3dff7796ca887e8368e4/w/8365d3095285df67b07ceb1b/e/3a59f6c1ef636442696465b0
