Drafting - Dimensioning holes (diameter or radius) in parts with curved or spline driven surfaces.
 mark_render
                    Member Posts: 10 ✭
mark_render
                    Member Posts: 10 ✭
                    In drafting whilst adding radius or diameter dimensions to views the software cannot detect radii and diameters on parts with curved surfaces or spline driven faces using the dimension commands.  A simple example would be a hole in a cylindrical shaft.
Apologies if have have missed something obvious.
2
Onshape doesn't currently support dimensioning these edges. We're aware of this and I'll add you to that improvement.
As a workaround you can add a note to the edge.
_Dave_
Thanks.
