3-D PDF of Arbor Press
sandy_beckersandy_becker Member Posts: 5
I was wondering if someone could create a 3-D PDF of the Arbor Press for me and email it to me. I do not have the ability at this time to make a 3-D PDF. I would like to use the Arbor Press in a couple examples for a portfolio I am trying to create. I will most definitely give Onshape credit for creating the Arbor Press.
Sbecker6599@sbcglobal.net
Thank you for any help that you can give me.
  • michael3424michael3424 Member Posts: 751 ✭✭✭✭
    If you have a link for the press, I'll see if I can generate it and send it to you.
  • sandy_beckersandy_becker Member Posts: 5
    It is Tutorial 3 - Make an Assembly.  Thank you
    Sorry, I should have read more closely.  I thought that you wanted a PDF of an Onshape assembly that you had created.  I haven't done that tutorial so I don't have access to the document.  Perhaps someone else can help.
    Thank you for trying.  Can anyone else help?
