Mate Question
I'm trying to figure out how to mate cylinder to a block. Say you have an 1/8" diameter dowel and you want to mate it to the edge of an 1/8" thick sheet. The end of the dowel is not necessarily cut perpendicular, it may be cut at an angle. Any thoughts?
Thanks,
Randy
Thanks,
Randy
jakeramsley Member, Moderator, Onshape Employees, Developers, csevp Posts: 664
I would create a mate connector for the dowel in the part studio at the point you want to connect angled the way you want. I'm not exactly sure how you want to mate these together though. What is the desired end result of them in an assembly?Jake RamsleyDirector of Quality Engineering & Release Manager onshape.com5
Randy
Thanks,
Randy
