Trouble creating derived features
brian_exnerbrian_exner OS Professional Posts: 4 PRO
I am making an electronic enclosure.  I want to insert the circuit board into my housing using the derived feature and then cut holes in the housing to match the connectors and mounting holes in the circuit board.  I can get it to work where I insert the housing into the circuit board, but not the other way around.  The PCB is not a derivable part while I am in the part studio containing the housing.  Am I doing something wrong?
    Hi brian_exner,
    Without access to your document, I am assuming the issue is that adding the PCB into your housing part studio might result in a circular dependency.  Does your Part Studio with the PCB in it already have a derived part from the housing Part Studio?  If so, deriving features back the other way is blocked as some of the geometry can be based on what was derived in in a circular way and not be solvable.
    If this is not the case, can you give more detail about your workflow?  The other possibility I can think of is that a single derive feature only allows bringing in from one Part Studio, not multiple.  Multiple derive features will be needed to bring in multiple parts from multiple Part Studios.
    Jake Ramsley
  • brian_exnerbrian_exner OS Professional Posts: 4 PRO
    Thanks for getting back to me, Jake.  There are no other derived features in this document.  The PCB was created as an assembly that was made up of a combination of parts I created and parts I imported; however, I then exported the assembly as a parasolid and imported it back into its own part studio.  Would it help if I shared the document with you, and if so, how do I go about doing that?  (sorry - I'm really new to Onshape).
    hi brian_exner,
    If you submit a feedback ticket and share the document with support, someone from our organization will try to resolve your issues.
    1. In the '?' drop down select 'Feedback'
    2. This will open up Usersnap, the feedback tool we use.  Enter a title and a description and make sure that the 'Share this document with Onshape support' is checked.  Someone from support will be in contact and be able to look at your document and see if they an find the root cause.
    1.png 121.9K
    2.png 128.7K
    Jake Ramsley
    Thanks for your help, Jake!
