Allowing "delete" in "view only mode" when over the 100mb free limit
juan_aviles
Member Posts: 78 ✭✭
I recently went over my 100MB limit...103 to be exact. This has caused my documents to be "view only". I have three large documents with only a few models in each that I really need. Is there a way to delete some of the non-essential models from each to lower my file size, or would this do nothing to help? I would assume that removing models from a document would reduce file size, but I'm not positive if this is how OnShape works. Is clearing history the only way?
I understand the documents being "view only", but I don't see how delete would violate anything in the free plan. Yes, I can export the model, delete the document and then import to a new clean document, but I'd lose the history of that particular part, correct? I can't copy and paste to reduce history, so is there another way?
I think Onshape could do better, but currently this is your only option.
I'll be glad when some more management tools become available, to make this kind of thing easier.
