Exporting to dwg/dxf question
nuno_castronuno_castro Member Posts: 2
edited July 2016 in Community Support
Hi,
It is possible to export the sketches to dwg or dxf format with quotes?
Regards,
NC
    Hi,
    Regards,
    NC
    Can you clarify what you mean by quotes?  We do allow exporting of sketches in dxf/dwg formats.  If you right click on the sketch in the feature list, there should be an option 'Export as DXF/DWG'.
    Jake Ramsley
  • nuno_castronuno_castro Member Posts: 2
    Hi jakeramsley,
    I mean export the sketch in dwg but with all anottations and references.
    See attached image.
    Regards,
    NC
