Folders/Organization
brian_rupp
OS Professional Posts: 13 PRO
I really need the option to organize my parts. I have many standard parts which we throw into an order so the base parts need to be easily pulled into the order without being modified. I envision under the my documents sections I could create the order number to open that up and eventually make sub folders when the list gets too long. I could also have a folder for my standard inventory parts "blocks" to insert into my orders.
https://forum.onshape.com/discussion/11/folder-in-my-documents
https://forum.onshape.com/discussion/954/is-it-possible-for-me-to-create-new-folders-in-my-documents
https://forum.onshape.com/discussion/2588/document-search-advanced-search-fields-and-filters-needed
If you dont have a proper plan how to organize documents and part studios , your company will have a bad end!
It is not easy I had a plan but it messed it all up . working on plan B++
