How to make an AR-15 rifle barrel
An AR-15 rifle barrel has varying diameters along its length. It also has a taper from the chamber near one end down to a smaller diameter a few inches away from that end. If you aren't familiar with this, just google "AR-15 rifle barrel" and you'll find some pictures to see what I'm describing.
I've created a single tube, of 1" diameter with a .223" bore. That was pretty easy. How do I specify the diameters of specific sections of the tube? Also, how do I create the taper near the chamber end of the barrel? I would like to be able to play with these diameters and the lengths of these diameters. Is that easy to do, or once I create a specific section of certain diameter, am I stuck with it? I tried this with SketchUp and there was virtually no flexibility to change lengths of varying diameters.
Thanks,
Jay
Thanks,
Jay
https://cad.onshape.com/documents/a0acd75a9d0d4a1a751f642f/w/1dd2693a236bb7d21dda7908/e/ede20c1d949b257f72bc4b7b
