Sweeping along a curve using multiple profile lines
james_markel
Member Posts: 2 ✭
How do I sweep along the curve so that it follows the three profile lines, tapering in the middle. When I run the sweep, I get the below image. Your help is much appreciated!
Step-1 Create datum planes in the mid of curves using Mid plane option
Step-2 Create additional profiles on created planes as below
Step-3 Create loft by first guide curve
Step-4 Create another loft with next guide curve
Thanks for your answer. Your answer almost worked, but it's created a concave surface (see first attached image). I would like a true sweep, where the edges run parallel to the center line (see second attached image). Does anyone know how to do this?
Thanks
