Importing different file types (e.g. obj, stl, 3ds) not working
Hi,
I have previously used Rhino 3D and Blender for my models, thus most of my models are in either obj. or 3ds format. When I tried to import them into onshape to work on them, the file is successfully imported but no model appears at all (totally blank). I saw somewhere that I could try importing the stl. version but still it did not work. Are there any alternatives as I do not want to work from scratch for these models again.
Onshape is a b-rep ('exact edge') modeler that professional engineers and designers use to describe geometry. This is in contrast to a faceted ('lots of triangles') modeler like Blender, Meshmixer, Tinkercad and others. These are primarily used by content creators for games and animations where exact dimensions do not matter. Two different approaches for two different groups of people.Onshape can generate an STL file, but explains why Onshape does not render .stl and .obj (and other mesh/cloud) formats - simply put, Engineers and Designers don't work with those formats.
B-rep
Faceted
When you import STL into SolidWorks, would you please outline the workflow that you use for the import and then what you do with it once imported?
Thank you.
