Offset in sketch = extrude problem
maciek
OS Professional Posts: 35 PRO
Hello,
I have a problem with a sketch. Contour is divided by offset spline, but if I move mouse over the sketch, it has a grey fill everywhere, so it means it's not divided ("inside" sketch isn't closed). As you can see, if I replace the offset spline with simple line, it works. I hope you will do something with this issue.
