Parameter control of dimensions
Hello everybody
I am working with the threads on bolts and in nuts, i I would like to use som kind of parameter control to change the dimension on pitch diameters an so on without having to go and change them manually. As in SolidWorks with the holewizard.
I hope you can help me
Best regards
Simon Magnussen
    Create variable before sketch / feature and call it with #MyVariable in input field.
