Constrain queries being passed into functions
In a helper function (not a feature), is there a way to replicate the 'Filter' part of an annotation for a query parameter, like in the precondition of a feature? I want to make sure that the query being passed in refers to geometry of a certain BodyType.
ilya_baran
Onshape Employees, Developers, HDM Posts: 1,245
You could make a precondition for this function and put there: evaluateQuery(context, qBodyType(q, BodyType.POINT)) == []
But the behavior we typically have in our standard library is to accept arbitrary queries, filter out everything we don't need, and then possibly complain if the query is empty.Ilya Baran \ VP, Architecture and FeatureScript \ Onshape Inc5
For the other filters allowed in the parameter filter, you can use qGeometry, qEntityFilter, and qConstructionFilter.
export function myFunc(context is Context, q is Query) { if (size(evaluateQuery(context, qBodyType(q, BodyType.POINT))) == 0) { // throw error or something } }but this doesn't seem particularly elegant. I guess it would be impossible for the code to know what the query would evaluate to without actually evaluating it, but it seems so clean when the UI just doesn't let you click on things that don't pass the filter. It would be neat if functions could do something similar where they automatically throw an error if a query parameter doesn't pass a filter.But the behavior we typically have in our standard library is to accept arbitrary queries, filter out everything we don't need, and then possibly complain if the query is empty.
