Angle constraint in sketch mode
Hi,
Is there a way to constrain the angle between 2 lines while sketching (i.e. for angles that are not perpendicular)?
thanks,
Jonathan.
thanks,
Jonathan.
1
LearnOnshape facebook group
this was exactly the point...
I somehow missed this method in the video, and was not used to doing it this way.
thanks!
EDIT:
OK I've worked it out. If you select two lines at once with the dimensioning tool on, it will give you the ability to enter an angle.
Easy when you know how. [sigh]
