I need to "Project" a part's face onto another (via sketch?) in an assembly. How to achieve that?
florian_ford
Member Posts: 54 ✭✭
I have an assembly where i put together different parts from different Part Studios. I need to "project" (Use?) the outline/shape of one part from one Part Studio on another Part (from another Part Studio).
But OS doesn't let me do this from the Assembly tab. I somehow have to bring the whole part in the other Part Studio to be able to enter sketch mode and "Use" the projected outline.
The problem is that the Derived list when I try to copy an object from another Part Studio is empty. If I go in the other Part Studio where i need the part from, I can click Derived and I get the list of all Parts in the other Part Studios in the document. Why would that happen?
-1
So, back to the subject at hand: I have made an Assembly arrangement of Parts from several Part Studios and I want to experiment different positions where to mount one part. I need to drag it and position it at precise measurements before comitting to a position.
When I decide for a position I need to use that part's mounting face as a template for the holes and recesses (etc). I am currently designing in SpaceClaim, which makes these tasks a breeze.
Can someone lay out for me a good way to achieve this simple workflow in OS?
Even the first part, the one of experimenting different positions in an Assembly seems an impossible taks because I can't seem to be able to do simple tasks like rotating the part to a precise angle. No Snapping at 15deg increments with the Triad, no moving by exact numbers by clicking on the arrows. Also I would find helpful some arrange and distribute mates that are single use.
So basically you should position all your parts at the exact angles in the Part Studio unless you have precise holes and/or surfaces to mate it with in the Assembly. At least there is one solution
I have to see how mating works in a Part Studio, I hear mates can exist in that.
I wish OS would combine the Part Studios and Assemblies in one workspace. I don't need to know where is what I only want to work on my design. All these partitioning and fragmenting of the workflow makes many of us resist switching. It might appeal to hardcore engineers but most of us like to experiment and prototype, exactly what DSM claims to cover.
To be correct, OS is very young and it still has a lot of time and room to grow up. We should be more understanding I guess. So maybe in 6 months try again. Until then, I'm doing here and there something just to take the pulse.
Whoever did that please explain maybe I am hurting some feelings and I want to understand and stop whatever it is that you don't like.
At least I am reporting back what I find so that the next guy doesn't have to go through this.
I hope constructive criticism and sincere opinions aren't something OS or OS fans want to discourage. We're free riders until OS will have decent fees for makers and we can at least do beta-testing and can give feedback. Sometimes harsh feedback yes, cause it's frustrating at times too
So... who was that:) ?
So I am moving and turning parts in an Assembly and when I like what I have I'd like to be able to "Use" the "mounting face" of that part to get the holes' positions and create the same holes on the mounting plate/etc. For this I need to enter "Sketch Mode" straight from the Assembly and "Use" the part I've been moving around.
I can share my doc, it's public: https://goo.gl/YcOsIW
I kind of moved past this by working around it I am not sure how can i demonstrate or better explain. I am sure this is about the workflow I am used to, so adjusting (or rather learning/figuring out) to OS expected workflow is not intuitive to me.
