Editing question in "Bracket" exercise. An early learner
I'm learning Onshape and doing the Bracket exercise. Everything went well until step 7 which called for changing two sides of the bracket from 148.5 to 180 mm in Sketch 2. The dimension will highlight but will not change. How do you edit this? It changes from black to red but does not change value. What am I missing?
Regards,
Paul
Regards,
Paul
peter_hall Member Posts: 196 ✭✭✭
If it changes to red it means you are over defining the sketch........probably a conflict with one of your constraints. If you share your document we may be able to point out which constraint is causing the issue.
5 -
øyvind_kaurstad Member Posts: 234 ✭✭✭
@paul_lynas If you check the button "Show constraints" while in sketch edit mode, you should be able to see the conflicting constraints highlighted in red.
5
