Onshape throwing errors in EVP
We are encountering an issue where Onshape is throwing errors when we commit in a feature studio, as below. This same error is showing the same error for almost all things we attempt to do in the part studio.
"Onshape encountered a problem with your last operation. If the problem persists, please contact support. Support code 55c3d2053926c4bea6b43cb2."
It seems only to be an issue in documents where the EVP is turned on. Any ideas what might be happening here?
    I am looking and I see a problem in the logs but not sure about the cause.  The issue appears to be with only one document.  Does copying that document help?  Please email me directly for follow-up.
  • amanda_sutherlandamanda_sutherland Member Posts: 14 EDU
    Issue fixed.
