Import existing onshape parts
brian_rupp
OS Professional Posts: 13 PRO
øyvind_kaurstad
Member Posts: 234 ✭✭✭
Within the same document, you would use "Derived" to obtain parts from other part studios, and for assemblies you would of course just insert the parts.
If your parts are in a differrent document, you would have to copy them into the document you're working on. You can right-click on a part studio tab (in the source document) and choose "Copy to clipboard", and then in the target document click the '+' on the bottom left and choose "Paste tab". Then proceed as you want to. However, the tab that copied has no relation to the source document, it is a pure copy.
5
