mirror offset spline
jerome_goyet
Member Posts: 16 ✭✭
hello,
Can anyone give me the trick to mirror a spline and the offset spline ?
I always get the following message : Cannot mirror offset splines.
The only way I found out is to delete the Offset constraint ...that can be cumbersome when you need to modify the original spline and you want the offset and mirror function linked to this spline.
Tks in advance for the support
Jérôme
Jérôme
- Sketch mirror line
- Sketch spline
- Offset spline
Sketch 2:- PROJECT/USE the offset spline (from previous sketch)
- Mirror the projected offset spline
PS: I violated the 1st rule of fight club and left Sketch 1 under-constrained. It pains me greatly.
