global data
billy2
Member, OS Professional, Mentor, Developers, User Group Leader Posts: 2,115 PRO
Is there anyway to pass around data?
createData creates a huge array, can getData access this array?
create some data:
create some data:
FeatureScript 307;
import(path : "onshape/std/geometry.fs", version : "307.0");
annotation { "Feature Type Name" : "createData" }
export const createData = defineFeature(function(context is Context, id is Id, definition is map)
precondition
const billysData=5;
}, { /* default parameters */ });
get some global data:
FeatureScript 307;
DATA::import(path : "03b271aa9f983f47f1473e51", version : "b5ddb1c97dd36645bc48123e");//link to createData
annotation { "Feature Type Name" : "getData" }
export const getData = defineFeature(function(context is Context, id is Id, definition is map)
precondition
// Define the parameters of the feature type
println('DATA::billysData '~DATA::billysData);
1. Variables (see setVariable and getVariable in context.fs) -- they may have any value including a large array.
2. Attributes (are attached to topology and are a little harder to use) -- see attribute.fs or the doc https://cad.onshape.com/FsDoc/library.html#module-attributes.fs
I figured it had something todo with context.
A module has context, and a module is located in a tab. I'm using 2 tabs, do they have different contexts?
Is context a document, part studio, module or tab?
Part studios have context, I have 2 modules in a part studio therefore they share 1 context?
Why would this ever be false?
If it's always true, why have it?
Can I run a function when it's not in context?
I can't get the simple one to work. I tried passing billysData=5 thinking this would be easy and it wasn't. So, I figured I'd give you a tougher problem closer to what I need. I'm interested in sending an array of vectors, 58,000 vectors. Maybe I'll just send the parsed x,y,z values. What's the best way to handle large data sets?
Questions:
1. how do you get this to work?
2. speed is everything. should I convert all x, y, z to vectors and then ship vectors? or should I send x, y, z around, pick the 1,000 I want and convert them?
3. are certain data types faster? arrays seem like they'd be faster than maps?
4. I am reading the manual (honest), you talk about a box value passing by reference as opposed to a deep copy, should I be using billysData[]=array? Wouldn't passing by reference be faster than any other methods outlined so far? I could be way out in right field. Not sure what a boxed value is used for other than accessing data.
createData.fs:
getData.fs:
and none of it works:
When you declare a function as:
you're specifying that the argument passed into foo must be a Context. It is an error (or warning if it is caught) if you pass in something else.
In your function, you're calling:
getVariable(context is Context, 'billysData');
and "context is Context" is indeed a boolean that always evaluates to true. But the getVariable function expects a Context, not a boolean as its first argument, hence the error. The correct call is (with the assignment to your variable):Now there's another issue: billysMap is not declared in the second feature so trying to pass it to getAttributes won't work (and even if it could be done, it wouldn't do the right thing -- like I said, attributes are a bit more complicated and I don't think you need them yet here).
Regarding speed, FeatureScript does very little actual copying, so passing around a 50k element array shouldn't be any more expensive than passing around a smaller one. One thing that is currently inordinately expensive (we're working on it) is modifying a large array. So maps are likely to be faster than arrays actually for now. The general rule is that YMMV so try profiling different things -- every use case is slightly different.
Hope this helps.
I'm passing arrays & maps. It's cool that the vectors stay true through the transfer. I thought I'd have to serialize my object before sending and then parse the variable on the other side. Nope, everything stays valid. You can store a lot in one variable.
Will run a little test and find out which is faster.
Here's the source for those who want to pass variables around feature scripts.
createData:
getData:
