How to re-use mechanical feature on multiple parts?
laird_broadfield
Member Posts: 42 ✭✭
So, I'm currently sketching a set of things that I'd like to FDM print so they snap together in various configurations -- think Lego blocks and you'll be pretty close.
I can't figure out a good way to develop a common snap (presumably the male part and the female part) and then readily paste multiple of it into my actual parts, at various places, in correct alignment to each other -- particularly when at least the female part probably consists of void space as well as positive space.
I think there's at least three questions buried in here that I'm having trouble segmenting; thanks for any attempts at answering any of them. I suspect this is closely related to discussions of standard parts or part libraries, but I don't see recent discussion/resolution.
Thanks.
Thanks.
NeilCooke
Moderator, Onshape Employees Posts: 5,933
Hi Laird - have you tried Derive in Part Studios? You can create a standard feature, derive it into another Part Studio, then use mate connectors and transform to place them.Senior Director, Technical Services, EMEA5
Kindly refer below video link which will be helpful to you.
