Mating two parts in iPad Pro
Erich_Koch
Member Posts: 27 ✭✭
Having problems mating two parts. See inserted drawing. Mated the corners of the two parts, then set up MOVE and entered the values for X=0.25, Y=3, Z=0. The parts do not mate. What am I doing wrong, or where is my usage of the mating function incorrect?
Should I used a different mate?
Thanks.
Thanks.
Even easier, you can probably skip creating the new mate connector and go straight to a mate and then move the mate.
Check out some of the videos on mating.
A quick tip:
1) single tap geometry of a part to envoke available mates
2) tap in space and hold to use the precision selection tool to select the specific mate
