How do I move a rectangle by a midpoint of a side to intersect/align with another object?
whtmountain
Member Posts: 6 ✭
I'm trying to replicate a relatively simple model I did earlier today in another program in OnShape to make a comparison of the time and effort involved between them.
And I got stuck.
I sketched a centerpoint rectangle over the corner of another rectangle. Then I needed to move the midpoint of the left side of it until it intersected another, larger, rectangle drawn around the original.
And nothing I tried would let me do that.
How do you do that?...without having to put a point out there, then draw a line the exact length you need from that point back toward the corner of the inner rectangle, and then drawing the centerpoint rectangle on that line endpoint?
Roughly shown here:
And I got stuck.
Roughly shown here:
Many try this as a start.
https://learn.onshape.com/courses/fundamentals-sketching
