Default value for a lookupTablePath?
dave_cowden
Member, Developers Posts: 480 ✭✭✭
How do you set the default value for a lookup table path?
When i set up a lookupTable path variable, i expect the default value to be the one selected via the 'default'
clause in the lookup table itself.
But what i find is that the value is empty until the user chooses a value from it, at which point, it is populated.
What is the right way to ensure that the initial value of a lookupPath definition field is set to the default values initially displayed?
ilya_baran
Onshape Employees, Developers, HDM Posts: 1,245
The hole feature regen doesn't look at the lookup table. Only editing logic does and it only looks for changes to it -- and after the first change, the value passed in is correct.Ilya Baran \ VP, Architecture and FeatureScript \ Onshape Inc5
const lookupTable = { "name" : "choice1", "displayName" : "First Choice", "default" : "y", "entries" : { "x" : "1", "y" : "2", "z" : "3" } }; annotation { "Feature Type Name" : "My Feature" } export const myFeature = defineFeature(function(context is Context, id is Id, definition is map) precondition { annotation { "Lookup table" : lookupTable } definition.p is LookupTablePath; } { // Define the function's action }, { /* default parameters */ });print( definition.p ) would give { "choice1" : 'y' } ?
for me in both cases, and before any user click, definition.p would be an empty set. I'll make see if i can make a simple document to repro-- may example is way too complex to post, so it coudl have a bug too.
In my case, for now the workaround was to do something like this in the editingLogicFuntion:
var lookupPath = definition.path
if ( oldDefinition == {} ){
lookupPath = lookupPath ( { 'choice': 'p' } )
this allowed me to continue as if it was populated as I expected. but of course this code is brittle because it is a duplicate of what's already in the lookup table.
