help with a mate problem i'm having
i'm NOT a CAD person! i know enough to get into trouble that's it. i'm trying to make a backhoe for my lawn mower and i can't get the mates to work. the angles for the cylinder and arm are most likely wrong, but that's why i'm drawing it on OnShape first.
any help would be appreciated.
thank you.
PS how do i attach the drawing
thank you.
https://cad.onshape.com/documents/56d9097ae4b0747e94b95328/w/0fc280872b93cdaa9bc0da08/e/c5052505afee9f50afee4205
1) Mate groups really reduce the number of mates - any two or more components that do not move relative to one another should be in a group
2) Sub assemblies really unclutter your tree
3) Mate connectors in parts and subassemblies make life easier.
4) try not to create chains of dependencies that must all be satisfied. For instance if i am building a 4 bar linkage, i will use 3 revolutes and 1 cylindrical mate relations. This accommodates any thickness variation between the 4 parts and visually moves any mis matched thicknesses to the cylindrical mate (and doesn't fail).
Thank you for your support of Onshape.
https://cad.onshape.com/documents/56d9ab56e4b0747e94b96693/w/7238edef32d289b762e69856/e/499eb516272ee9ddab370e8c
Fixed - you only need one
https://cad.onshape.com/help/index.htm#cshid=mategroup
