Issues with KeyShot
CadmanCadman Member Posts: 12 ✭✭
Has anyone downloaded and installed KetShot rendering software that is available on the OnShape App Store? I did, following the directions and it downloaded and installed ok. However, when I attempt to run it I get a Windows error stating that something caused this application to stop working and it shuts down.
I have  yet to even get it to open successfully.
Any ideas?
Randy
  • heine_stokholm706heine_stokholm706 Member, Developers Posts: 1
    Are you perhaps on a Dell computer? There is a known issue when running dell backup and recovery software.
    Otherwise I would contact support@luxion.com directly.
    - Heine
  • CadmanCadman Member Posts: 12 ✭✭
    No.... I am using an HP Pro.
    Thank you for the reply. I will try to contact their support.
