15 mins without getting connected!
peter_hall
Member Posts: 196 ✭✭✭
9-00am to 9-15am in UK
All I get
We need a method of telling users when Onshape is down, if this is the problem. Not had this before? Is this an issue using a browser based CAD system?
All I get
The problem has been resolved. We very much appreciate your patience and apologize for the lost productivity. I've created a post at:
https://forum.onshape.com/discussion/3408/performance-problems-8-march-2016 .
Please let us know if you are continuing to see problems.
John Rousseau / VP, Technical Operations / Onshape Inc.5
Hi @peter_hall - I am in the UK and had no problems. Did you try loading another document?
Senior Director, Technical Services, EMEA0 -
@NeilCooke No but I tried loading various tabs within same document, one the table came up after a long period of time.
I will go off now and try to load another document of similar size and also an easy one!
and that is a small document! No good.
OK I'm seeing it too now - it was fine earlier this morningSenior Director, Technical Services, EMEA0
Me too
@NeilCooke Ok, at least I know its a general problem I will try again later. I was worried that it might be because I gave connection permission to Keyshot App.
I've been getting this also. Frequent dropping back to blue disconnected over the past hour.
Me too, not very happy!!
Try it again - you should be seeing some improvement, but still not there 100% just yetSenior Director, Technical Services, EMEA0
