how do you draw a twisted pair of wires?
 matt_eden
                    OS Professional Posts: 1 PRO
matt_eden
Thanks in advance
                Thanks in advance
                 1
Thanks,
by extruding a 0.1 inch cylinder 12 inches long, creating a helix with 6 turns on the cylinder's surface, creating a second helix with 6 turns starting at 180 degrees, creating two circles of 0.02 inch diameter centered on the ends of the helixes, then sweeping each circle along its helix.
There is probably a much easier way. I'm very inexperienced with 3D CAD and Onshape.
Jon
http://forum.onshape.com/discussion/242/best-way-to-record-gif-video-of-using-onshape
https://cad.onshape.com/documents/1314ac15a3a2b3cae8970ba0/w/80e5f0686a8f91093276fe97/e/84db1321627796104c56394b
https://cad.onshape.com/documents/f39d3f0d833818b268e24480/w/75bbb50678b5bafb6c6eee68/e/0da5e3e8f2cac9a48c3392b7
Many thanks!
1. draw a helix along a straight rod as below,
2. Create a Sweep by using helix as path and circle as cross section.
3. Pattern the wire.
Thank you in advance
Linked[in]
Cheers,
https://cad.onshape.com/documents/521f46b2bd7a574dde89d5ea/w/d563a9f2bfe13ed242c448fb/e/ee0e3cef684cd7149b8825eb?renderMode=0&uiState=624ab1fcd0c7bc7721728700
