2 Noob questions about multiple parts in a single parts studio
gw_estep
OS Professional Posts: 13 PRO
I've imported a model into a parts studio and began modeling a mounting bracket for it. The problem I have is the bracket is somehow inseparable from the imported part. I'd like to make the new bracket a separate part but can't seem to figure out how to separate them. Here is the model
https://cad.onshape.com/documents/56df631ee4b0d96417a492e8/w/c31ff85db099b2a57ef4b0f2/e/ce589309ec38cfcaa7d7588a
Next noob question, how to I make a new part and prevent this from happening next time?
coleman
OS Professional Posts: 244 ✭✭✭
Hi @gw_estep- The answer to your question is simple- when you are creating a new feature (extrude, revolve etc.) you will need to select "NEW" in the feature creation dialog window. Just edit your extrude....it should currently say "ADD"....this is the value you want to change to new.
When you add features to existing parts....new feature body will inherit the color of the parent part (the part you added to).
Conversely, when you create a NEW part...the new body will adopt a new color and you will see a new part added to the part list (bottom left).
5
