Cross curves
bryan_lagrangebryan_lagrange Member, User Group Leader Posts: 976 ✭✭✭✭✭
edited March 2016 in Community Support
In Solid Edge there is a feature called cross curves. If you are to draw a sketch on the front plane and then tangent to that draw a sketch on the top plane you can use the cross curve command to create the combination of the 2 to form a 3D curve. Is there something like this in OnShape?
Bryan Lagrange
Twitter: @BryanLAGdesign
