Cross curves
bryan_lagrange
Member, User Group Leader Posts: 945 ✭✭✭✭✭
In Solid Edge there is a feature called cross curves. If you are to draw a sketch on the front plane and then tangent to that draw a sketch on the top plane you can use the cross curve command to create the combination of the 2 to form a 3D curve. Is there something like this in OnShape?
This is what I am trying to achieve. A 3D sketch derived from 2 2D sketches
Twitter: @BryanLAGdesign
