Sketch projection
bryan_lagrange
Member, User Group Leader Posts: 980 ✭✭✭✭✭
cadmando
Member Posts: 68 ✭✭
Hi Bryan,
Is this what you are looking for:
https://cad.onshape.com/documents/681648ffe980ab10a397fa9a/w/f17369e263bd9407d9694fcd/e/b534b649add697985ad6e592
1: Extrude the sketch, up to face
2: Create a sketch of a cylinder with internal dia larger than original cylinder by the amount you require the raised section, the outside dia will need to be large enough to encase all the sketch you extruded to face and select remove.
Hope this is what you are looking for, if you have any questions, please ask.
Graham
5 -
Narayan_K
Member Posts: 379 ✭✭✭
@ bryan_lagrange, the other method is extruding(surface Extrude) the sketch up to face and using the edge of the surface for you further operations.Similar to your previous question.
5
I am looking to do this:
Twitter: @BryanLAGdesign
Graham
