In Onshape, what is the best way to edit something created on Catia v5?
stephen_brzykcy
Member Posts: 4 ✭
Hi, so I have imported the .CATpart file and have a sketch with the object loaded but I can't seem to change the placement locations of the lines, is there a different way to do this? I am not adept at CAD, which is why I am having someone else do the heavy lifting (and they use Catia v5), please let me know the best method to take a model he creates and edit it. Thanks!
Narayan_K
Member Posts: 379 ✭✭✭
You can't edit the hole position by editing the sketch.But you can do it by direct editing method as shown video,
https://www.onshape.com/videos/direct-editing
5
By the help of above tools you can modify the model.
