Why does order in selection of loft profiles / faces matter
I'm confused as to why the program works as intended when you click in one sequence, but either goes red or comes up with something crazy in the other sequence. If I knew why it mattered I could stop guessing, but as of yet have not seen a pattern for it..
Thanks
Thanks
In general, with lofts that have many profiles, you want to select them left to right, or right to left, in order.
