Creating a radial array of holes
da_prop_makerda_prop_maker Member Posts: 4
I'm trying to create a series of equally spaced counterbored holes, on a surface around a circular path, essentially creating a radial array.  I just started using this 'software', so I'm still learning.  I've been using SketchFab, so this is all new to me.  Thank you for any help :)
  • shanshanshanshan Member Posts: 147 ✭✭✭
    in Onshape ,we have to create a sketch which is used for hole feature first.
  • da_prop_makerda_prop_maker Member Posts: 4
    shanshan said:
    As a newcomer, Tutorials and videos are very helpful for you ,please see the attached picture , you will find them in Onshape page
    I did do the tutorials...I must've just missed this one.  Thank you again for the help :)
