Improve response time of a design?
gillspicegillspice Member, Developers Posts: 2 PRO
I have a public design that is based on a pretty involved sketch, it seems that the sketch complexity is causing the design to be unresponsive, can you take a look to see if perhaps I could implement in a way that would improve response time?:
https://cad.onshape.com/documents/56ceeab3e4b02da21b9feda8/w/5d7a1bfed07b1d84df75d560/e/015341f0aedf71a0ae3f06ec
    One thing I noticed is that on your more vertical lines for the frets, they are composed of two separate lines (that are mirrored I assume).  You might get better performance with a single line and mid-point/symmetric constraint for those.  This should reduce the number of lines to solve by 352 (if I can count correctly).  Similarly you probably don't need the mid-line and the bottom edge as construction lines to constraint to for each row of frets.  Depending on where the points are constrained, could reduce the number of constraints on the sketch by 176 (again if I can count correctly).
    Jake Ramsley
