fillets
gideonwaldnergideonwaldner Member Posts: 32 EDU
edited March 2016 in Community Support
can you make a fillet like the red shows
gideon waldner
    Depends what the two entities are.  If you have a circle with a line through it, filleting the circle doesn't work, it needs to be split first.
    As it is now two arcs, the fillet between the line and arc can be made.  First select the line to the right of the arc.  Then select the arc above the line.
    3.png 72.1K
    4.png 75.6K
    Jake Ramsley
    When in doubt, just make an arc, and then add in tangent constraints at the ends...
