Lower Case i
daniel_splawskidaniel_splawski Member Posts: 66 ✭✭
Would it be possible to alter the font that you use so that the lower case I has a dot. Currently it's full height and I often confuse it with a lower case L
  • lougallolougallo Member, Moderator, Onshape Employees, Developers, csevp, pcbaevp Posts: 2,015 image
    Ticket has been logged for you.
