Mismatch of system Axis
heiko_pressel
Member Posts: 9 ✭
Hi everybody,
I need your Help!
For some unknown reason the Axis of the System and the axis of the triad manipulator of the Assembly don't match.
Can anyone tell me what i did i do wrong and how can i realign them?
Thank you
I need your Help!
Thank you
Optionsviru Member, Developers Posts: 619 ✭✭✭✭@heiko_pressel, I gone through your assembly in which you have given fixed relationship. kindly refer below image.
After removing fix relationship you can move your assembly. Kindly refer below video for more detail.
8
You can match it by rotating the part as below.
Thanks for your answer, but the problem not solved yet.
I cannot rotate. The triad manpulator snaps back to its former position after releasing the mouse button and it does not take the assembly with it, as it does on your (very nice) example.
Even if it would, how could i allign it "perfekt" with the system Axis, so it shows in line perfekt in the end on the drawing?
If i try to allign with the triad manipulator with the Z axis by a right mouse click it gives me
"unable to apply transform,
instance(s) may be constrained" ??
There has to be a kind of bug, sometimes Onshape lets me move the assembly by left mouse klick, and suddenly it only is possible by klicking the mouse wheel???
That sucks!!
Thanx
Heiko
now i got the triad manipulator alligned with the system axis but the whole dammed assembly stands square??
I would like it all to be alligned.
and i would like to "move it, move it" ;-))
1) First you have to give mate relationship with respect to each part. If you did not want to give each constraint initially then select each parts and give group constraint.
2) Now select fastened mate constraint and select mate connector of part and mate connector of origin.
Kindly refer below video which may be helpful to solve your problem.
thank you very much for your assistance.
I tried your solution with a example and it worked perfekt.
But!
I'm coming closer but it still dosen't work.
With the Help of your tutorial i found out that the assembly has a fix (ed?) relation to the origin. Thats the reason why the object allways snaps back when i'm using the triad manipulator. Orientation as well as position to origin. For that reason it also is not possible to realign the assembly with the systems axis system.
I checked all parts and subassemlies but cannot find why the assembly is fixed to the origin.
I also found out that i can move Assemblies, that are not fixed to the origin, with the left mouse button but assemblies fixed to the origin can be moved only with a clic on the mouse wheel. for that reason suddenly while working the movement of the assembly by left mouse clic is disabled. That's when the Assembly get's (i don't know why) fixed to origin.
Still hoping to solve it;-)
Can you share your document with us then we can go in detail and find solution for you.
Thanx for your assistance.
I checked and didn't find a fixed objekt in my construction.
I published the whole work under "Vierkantstahl Cubus"
https://cad.onshape.com/documents/40986132b08c47a7952f508d/w/5c9561b8296a4ed5bd03c3e6
The assembly that causes problems is "Ass Zus Bau Kpl"
You should be able to open the Problem ;-))
Ill be happy for any further idea.
Heiko
THAT'S IT!!
Thanx a lot. I was not careful enough!
Great and very patient help!
Nice not to laugh out loud. It's kind of embarrassing anyhow.
I'm glad i can work on now.
Great community.
Once again, thank you for the Help.
