How to wake midpoints to use as constraints?
Midpoints will not wake unless I choose something new to draw e.g. a new line. I'd like to use constraints directly on midpoints but Onshape tells me; "A constraint must involve something from the sketch".
Did I miss something?
Narayan_K Posts: 379 ✭✭✭
Firesale said:Midpoints will not wake unless I choose something new to draw e.g. a new line. I'd like to use constraints directly on midpoints but Onshape tells me; "A constraint must involve something from the sketch".
Yes, I agree with your point, mid point will not highlight/snap for dimension and applying mid-point constrain between two lines unless we have a point.
5
I would first create a point at the mid of each of the 2 lines, select the 2 points and then use the coincident constraint.
Or ...
Create only 1 point at the mid of one of the 2 lines, select the point and the other line and then use the midpoint contraint.
Result:
Thanks, that works but I think the "wake midpoint" should be active on constraints also. Oh, and on Dimension also. A huge step-saver!
Bottom line is; I don't see any good reason for putting it to sleep:)
I am sure there is a more complex reason for them not to wake.
BTW @hakro ; nice screen caps, do you use Snagit?
