Attach pipe off axis
richard_nehrboss
Member Posts: 2 ✭
Hi,
I'm trying to create this shape. I can handle the cone.. revolving a sketch, thickening the surface etc, but I'm having trouble with the offset pipe on the side. I can create a sketch, revolve a pipe, thicken and have it through the middle, but don't know how to get it offset and split it so it's flush with the cone.
Any help?
Thanks!
Any help?
Thanks!
Then I revolved this shape to make the cone. After the revolve, I created a new sketch on the original sketch plane, and added a circle of 55. (This circle could have been placed on the original sketch)
Then I extruded that circle
Then use delete face to get rid of the hump
that looks more like the diagram you posted, but it's still not exact. I don't know how to figure this exactly by using OnShape tools, and I'd need to refresh on some geometry skills to figure it manually. Speaking of which, is that diagram that you posted pulled from a text book?
