Problem with liner pattern of feauture
OpenR2
OS Professional Posts: 188 ✭✭✭
So if I take a sketch and extrude a fixed distance I can linerar pattern the resulting feature with expected results.
If I take a sketch and extrude up to a plane....when I try to create the linear patter...it tries to keep the plane used in the definition fixed instead of offsetting it.
Is this intended? I think this might be a bug.
