Problem with liner pattern of feauture
OpenR2OpenR2 OS Professional Posts: 188 ✭✭✭
edited April 2016 in Community Support
So if I take a sketch and extrude a fixed distance I can linerar pattern the resulting feature with expected results.
If I take a sketch and extrude up to a plane....when I try to create the linear patter...it tries to keep the plane used in the definition fixed instead of offsetting it.
Is this intended? I think this might be a bug.
  • chris_8chris_8 OS Professional Posts: 102 PRO
    I'm not sure which plane is fixed in this picture or how it might offset.  could you elaborate?
  • shanshanshanshan Member Posts: 147 ✭✭✭
    OpenR2, I could not understand your question very well ,  could you describe it in detail?
  • michael3424michael3424 Member Posts: 756 ✭✭✭✭
    Very clever Narayan, and easy to grasp with your screen caps!
  • OpenR2OpenR2 OS Professional Posts: 188 ✭✭✭
    OK...that is a little different....but let me try that....it looks like that will work.
