Specifying hole depth in drawings?
michael3424
Member Posts: 751 ✭✭✭✭
in Drawings
How is one expected to specify hole depth in a drawing? Hole condition (depth, countersink, etc) in callouts aren't implemented yet and it looks like you can't dimension to the hidden lines in a drawing when they are "revealed" either. Is manual entry in the hole callout the only available option right now?
"6x1 mm thread, through
Φ 5 mm"
where the "5 mm" part is the the standard minor diameter for a 6x1 mm hole. I'd like to eliminate the second line from my drawings. Is there a way to do that?
