inverted truncated pyramid with open top
How do I make an inverted truncated four sided pyramid with an open top. Ultimately I would like the corners to be defined as box joints, and am hoping that I can use the drawing to determine the angle of the saw when making the cuts. I've created the basic shape many ways, but I can't get it to be hollow and no top.
This is pretty much what @cadmando suggested. I'm not sure what the best way is to break it into individual parts is though. However, if this is the general shape you're going for, I'm sure a few people will have suggestions.
https://cad.onshape.com/documents/7287b4e86e87c88d8064de6d/w/ec4fe057bbe02f84a273eb55/e/45bbc47594216a5acbf33205
