Extrustion Not Removing Wall Face in Circular Pattern
Hi Ya'll. Below is a link to a drawing I'm working on. Can someone please help me understand why the inside wall of Extrusion 5 is not removed? And as a result, none of the inside walls of Circular Pattern 2 are either. The square tower extrusion has all equal sides of 4.5mm with the inside edge having a Tangent Constraint in the inside wall. I thought the combination of those 2 Constraints would fully define the sketch but apparently it's not. I'm at a loss because I recently made a separate drawing where the same idea is being drawn with the extrusions facing the outer wall with the same constraints and it worked perfectly. So, I'm not sure why this is acting differently. Thanks for the input.
https://cad.onshape.com/documents/2b1af4daa0f69c81edd26e04
Or search, "Outer Storage Tray"
Note: search for, "Center Storage Tray" to see how the extrusion Circular Pattern worked on the other drawing. The outer wall was removed.
Thanks,
Joshua
Thanks,
Joshua
