45Deg Pipe Mitre
kenneth_maciverkenneth_maciver Member Posts: 1
Hi. New to Onshape. I have a length of pipe that I would like to put a 45Deg mitre at one end and I have no idea how to cut this shape into the pipe. Be grateful for any assistance. many thanks
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,927 image
    If you have a plane going through the axis of the tube, create a sketch on that and draw the area to remove, then extrude/remove
