Use a part to make a hole in another part
henrik_ehlerthenrik_ehlert Member Posts: 1
hey,
i am making a box In parts studio - and I need to make a cutout in one of the sides for a connector - I have a step file of the connector, but I can't find any way to import this file directly into part studio (so I can subtract it)
Best regards,
Henrik
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,933 image
    Use the Derive feature, then Transform using Mate Connectors.
    @henrik_ehlert, Kindly follow below step which will helpful to you.
    Step-1: Import step file of the connector in Onshape document.
    Step-2: Use derive feature for inserting connector part into box part studio.
    Step-3: Use transform operation using mate connector for placing connector part at required position of box.
    Step-4: Perform Boolean subtract operation to get desired result.
    Kindly refer below video for more detail,
